Anyone got a link for cat delete install?
I'll take some pictures when I do mine in a week or two. I will be installing the Supersprint delete pipes. Already had one cat detach and create an idle rattle from a lot of track usage. Now that I am out of emissions warranty I don't want it to happen again....
3 bolts on the hears side - two bolt on the sleeve on the muffler side. This is not brain surgery folks.
Expect the 3 bolts on the header end to break or be frozen from the heat. If you ever plan on using the cats again be very careful to keep any oil or penetrating fluid away from the oxygen sensors - even a small amount will ruin them.
Buy new nuts and bolts for the header side.
