Thermostat Replacement?
Strictly speaking it is not necessary if the engine temp. act still as it should, however, after 10 years i would have done it to be sure, it's not much more work and not expensive.
I just replaced my water pump on my 1999 996. I was wondering if I should have replaced the thermostat as well? I'm a bit concerned that I did not.
Harry
Harry:
It's only four 10mm bolts, one radiator hose clamp, and a partial coolant drain to replace the T-stat. If you have tackled the water pump yourself, it should be an easy DIY for you.
If you are only replacing the T-stat, I understand that a special tool is required to remove the T-stat from the housing, but IIRC the tool can be improvised.
Regards, Maurice.
Harry
Harry:
Regards, Maurice.
How to improvise the thermostat tool? Does anyone have pictures?
