Assistance Needed. pp C2
Assistance Needed - CEL After Spark Plug Change 1999 C2 (standard)
I changed my plugs and tubes 2 days ago, and the car has been running great. This morning, about 20 min into my drive I went to pass and the car sputtered a bit, and the CEL came on. Checked out the codes, P0134 which is the 02 sensor, and P0302 (cylinder #2 misfire). I checked all of the connections and they seemed to be okay. To trouble shoot, I took the #2 cylinder coil and moved it to #1. Took it for a test drive and had the same problem, sputtering when I get on it. Checked the codes again, and the same codes were noted. I then changed #2 spark plug, and the same problem. Would a bad o2 sensor have the symptoms of sputtering?
My questions are :
1. Would a loose connection to the coil pack cause this (P0302 code)?
2. If the o2 sensor is bad would my symptoms be; sputtering when I get on it?
3. If the problem didn't follow the coilpack, would it be that I have a bad plug in #2?
4. Would the o2 going bad cause a fault with cyclinder #2, and or vise versa?
Any help would be appreciated!!! Thank you!
