OK so this forum has been recommended by Piston Heads members so I hope someone can help...
My Boxster has been garaged and not used for 2 weeks. I went to start it the other day and nothing! all electrics fine (seemingly) just nothing from the engine!
So i have trickle charged the battery, - nothing. I have tried to jump start using the hitech kit borrowed from my local garage - nothing. (battery showed 13v on the meter so seems ok.
It was suggested on the other forum that i disconnect the battery for 30 mins and then reconnect and try - i did this and the car started first time! So i drove it round for 20 mins then left it out front. As i locked it using the remote i did notice that a few seconds an unusual bleep came from it, a sound which i never heard before) 10 mins later. the car wont start again so i took a deep breath, disconnected the battery again for 30 mins and then it again started first time effortlessly.
This time i put it back in the garage and as soon as i turned off the engine, i went to restart it and .... nothing! (i had not even got out of the car)
so now it is sitting in the garage. and i am sitting here typing this and exasperated!
any assistance gratefully received.
:welcome:
The system shuts down after 5 days of inactivity to save the battery.
Next time you can just lock and unlock the door using the metal key to reactivate the alarm/immobilizer system. (This info is actually in the owners manual).
:welcome:
It also sounds like you have a bad battery. I would remove the battery and take it to AutoZone, PEP Boys or similar and have them load test the battery. If you have a way to check for any fault codes. Sometimes places like AutoZone will loan you a code reader. Although they typically only catch emission codes. Not a reliable as a Durametric or other Porsche specific reader. Fault Code 1602 indicates a bad battery.
What year of Boxster is it? Tip? S? 5 speed? It is helpful to include specs on future posts.
Welcome again and maybe someone else can chip in on immobilisor possibility.
:welcome:
Well i did think this about the battery but like i say when i disconnected the battery and reconnected after 30 mins it started first time.
it is when i turn off the engine it just wont start again unless i disconnect the battery again for 30 mins
:welcome:
Yep i am aware of this. Like i say (or maybe i didnt!) i have used the key in the door to reset it but, as soon as i turn the engine off it wont start again.
using the key to reset doesnt seem to do anything on this problem
Well the car is now unlocked in the garage and wont start.
$ times I have disconnected the battery for 20mins, and then after the reconnection it starts first time with ease! but as soon as i turn off the engine it wont start again unless i disconnect the battery again for 20 mins!
useless!!
:welcome:
Thanks I will remember that!
It is a 2000 Boxster 'S' 6 speed manual.
You need to get it checked by someone with a Porsche Tester. It should show up any faults in the alarm control module, which contains the immobiliser.
Try Addspeed at Horsham, or there is a new Indy near Gatwick called NineExcellence.
