98 Boxster obd2 code p0446
P0446 is the code thrown when the EVAP canister purge air line is blocked. Usually just needs a compressed air blow out of the purge air line. The same code can also be thrown if the EVAP canister itself becomes totally blocked, but that happens very rarely.
