suspension upgrades
I use a lot of the tarett stuff. I like it, and think Ira does a good job with customer service.
I recommend softer springs, though, than what the spec guys run - I started with 450/500 and have, over time, moved down to 400# all around.
which tarett pieces are you using?
I went with the ROWM030 suspension upgrade and it solved all my track issues on my '99. Best bang for the buck suspension upgrade out there.
I am running a 97' with 75,000 miles. Is this the general consensus that the entire Row M030 suspension, including springs, struts, sway bars and bushings, is the best way to go for better street handling?
