hi ive started getting problems with my pcm ,i installed the maps and everything runs ok the map moves where it is supposed to but when i enter an adrress it keeps saying install cd ,i have even loaded other country cd `s and reinstalling the correct country to no avail .has anyone got any ideas?
Is the address you are entering in a different location (map range) from the CD you have loaded in PCM? Here in the US, for long road trips, I need to change CDs on ocassion as I travel out of the CD-map region. I have an '04 Cayenne S, CD-based PCM, and I can't load all the map CDs in the system at once -- you need to keep the CD map of the current region always in the PCM CD-player -- for the region you're in. Then you change CDs as needed. So if you're in Bucharest and enter a Paris address the CD would need to be changed. Hope this makes sense.
Edited by odix
thanks for the reply actually the problem is local adrresses and it doesnt just happen in romania .also if i try to play a cd that was made on computer it rejects it ,is that normal as well,i installed denison 500 because the cd changer gave up the ghost. i have had to buy another gps which sucks.from what i understand it is not easy to upadate to a later pcm because of the bose. why is it the chinese can make a plug and play system but porsche cant be bothered..
