Click here to Donate
odix
  • Content Count
    285
Everything posted by odix
  1. These are great: http://smartercharger.com/products/batterychargers/ctek-multi-us-3300/ They are Porsche OEM. Porsche places their logo on the Ctek charger. I use mine monthly -- via the passenger footwell jack.
  2. To Loren's point, become a contributing member and you can run the VIN and learn a lot more about the vehicle. Money well spent.
  3. Year of your Cayenne? How old is your vehicle battery? How much voltage is your battery putting out? Old/weak batteries can generate many problems, including settings losing their memory.
  4. Hi smallfrys: Regarding recalls in general -- not sure what automobile manufacture regulatory bylaws are in Australia but in the US a problem has to be consistent and persist over a certain time frame (early in a vehicle's release) and a large percentile of vehicles in release have to be significantly impacted. The problem has to be an issue replicable by third parties. Many vehicle manufacturers issue voluntary recalls (in North America) but those recalls differ from mandatory recalls. Major safety issues will prompt regulatory bodies to act quickly and this is often based on number of im
  5. An excellent indy shop I've taken my '04 Cayenne S to in the SF Bay Area is: Pro Shop in San Rafael. 58 Irwin Street. Tel: 415/454-2966 German-owner, Vots, used to race 911's back in the day. He has all the official diagnostic tools, reasonable pricing and is a direct and straightforward person. I bought my Cayenne used (Certified Pre-Owned) and also like Sonnen Porsche (official dealer) in Mill Valley -- it's where I purchased the vehicle. Dealer service pricing is, in my opinion, higher then it needs to be. Vots and his team do not wash your vehicle or shuttle you around town but they g
  6. Become a contributing member and I think you can find your answer in the DIY section.
  7. How old is your main vehicle battery? And have you recently replaced the key fob battery?
  8. I too drive an '04 CS. They are complex, heavy vehicles with large engines and a lot of heated fluids circulating around. Porsche gauges reflect reality and in reality vehicles with internal combustion engines generate more heat while stationary and all vehicles experience significant temperature ranges, It's normal. Most mainstream vehicle (non-Porsche) coolant gauges are calibrated to hold the mid-mark to keep folks from freaking out. It's a perception issue and you'll find a few threads on this topic here in Renntech.org. For example my '03 VW Golf/GTI's coolant temp gauge holds the m
  9. You'll find a thread here on how to remove the side-mirror glass. It's easy.
  10. I own a 2004 S and the radio (PCM 2, CD, not DVD nav) and reception are excellent. Once you sort out your issues you'll be pleased with the radio.
  11. Be sure your vehicle is stopped and in park when you look for the comfort settings. While in motion certain settings/features are innaccessinble.
  12. If you are under warranty I'd suggest you make an appointment today. Sonnen Marin (I see you are in the SF Bay Area) are solid. I had A/C water drip over my accelerator foot a few years ago (I have an '04 S) -- and the cause was the drain plug on the passenger side foot well was blocked and overflowed -- a few threads here cover it. And what's odd is the drip felt really hot to my foot but it was actually quite cold. The human nervous system has strange reactions. By the time I stopped and took a look the water on the carpet felt warm to the touch because, by then, it was indeed warm.
  13. I too will consider LEDs if we can all locate ones that do not drain the vehicle battery. For now all I want to do is add LEDs for the overhead console (three bulbs). I know very little about electrical current but one thought to consider -- the heat may not only originate from the incandescent bulbs filaments -- heat may also originate from the current running to power the bulbs, any bulbs. The melted section (from what I recall) of the housing was not exactly where the bulbs were housed. LEDs draw much less current but switching to LED bulbs (even if the battery drain issue is resolved)
  14. Tutorial here: http://www.renntech.org/forums/tutorials/article/269-2004-cayenne-s-center-ceiling-panel-melted-housing-repair/ Also -- what LEDs did you guys use for the overhead lights? The replacement parts are the same and will, over time melt again if left on. Please post the LED info. Thx.
  15. ciaka, if you become a Renntech contributing member you can download a few brake DIYs. Well worth the membership costs. You'll see pictures and details of what to replace when you do your brake job.
  16. I agree with Mudman. You can search this air suspension issue on Renntech and the web overall and you will see what Mudman states is correct.
  17. Natty -- thanks for the note that my tutorial file as too small. I added a .pdf file with bigger pics. You may need to be a contributing member to download it. Glad you're all set with your spare. Happy motoring!
  18. + 1 on the above post. Take a close look at the driveshaft. Lots of info about their failures and replacement steps here on Renntech.org. Search for "cardan shaft". I had to replace mine and the early symptoms mirror what you wrote you've experienced. '04 Cayenne S.
  19. Nope, it will not fit. 18" is your minimun to clear brakes.
  20. Thanks for the update. Glad it worked out and good battery tip as well.
  21. ekstroemtj nailed it: it's your drive-shaft. Your description is the exact same for my vehicle (2004 Cayenne S) as the shaft slowly failed. The threads noted above will sort you out. Good luck. In my case I was under CPO so the dealer took care of the replacement.
  22. I think you have HID headlight bulbs in your vehcile. Did you replace the associated supporting ballasts (called the Ballast Control Module) along with the bulbs? If a HID bulb totally fails it can take the ballast with it and you'll need to replace them as well.
  23. Hi Nylon: Congratulations on your Cayenne purchase and welcome to Renntech. Be sure to search these forums and you can read up on all the issues and items to cover if and when you replace your coolant pipes -- what else to do while you're in there, etc. (You can also read about some other methods to check exactly what pipes you have installed.) And for your hitch -- if you become a contributing member you can review the DIY section which has a lot of hitch details, pictures and instructions. Happy Holidays!
