Engine warning light - Duratech codes explanation?
My wife's 2004 CTT has 70K miles and has been rock solid since we bought it over four years ago. The engine warning light just came on and I pulled the following codes this morning:
P2187 - System at Idle Bank 1
P2189 - System at Idle Bank 2
P0441 Evaporative Emmision System (incorrect purge flow present)
I cleared the codes, however the next time that my wife drove the car this afternoon the engine light came back on.
It appears that the car is running a bit rough (according to my wife as I have not had the chance to drive it yet). It felt fine when it was idling when I was pulling the codes, but I did not get a chance to drive it to verify the rough running.
Any suggestions on what the problem is?
Thanks - Steve
P2187 Oxygen Sensing Adaptation, Idle Range, Bank 1 (RKAT1) - Above Limit
P2189 Oxygen Sensing Adaptation, Idle Range, Bank 2 (RKAT2) - Above Limit
Possible fault cause
- Incorrect main charge signal
- Intake air system leaking
- Fuel pressure too low
- Volume supply of fuel pump too low
- Mechanical fault in injection valves
- PCV valve leaking
- Cap of oil filler neck leaking
- Leaks in exhaust system
- EVAP canister purge valve mechanically faulty (hangs open)
- EVAP canister purge valve output stage faults
P0441 Fuel tank ventilation system above limit value/below limit value
Possible cause of fault
- Tank vent faulty (remains stuck in an open or closed position)
- Tank vent installed the wrong way round
- Leak in scavenging lines between tank vent and positive crankcase ventilation (in the Turbo via a T-piece also on the intake side of the turbocharger)
- Scavenging lines between tank vent and positive crankcase ventilation trapped or blocked (in the Turbo via a T-piece also on the intake side of the turbocharger
The EVAP solenoid is a known fault which will cause a vacuum leak with rough running and intermittent hard starting. Verify there are no vacuum leaks, replace the control solenoid and clear all codes.
Along with P2189 I also got P0507, P0300, P0301 and P0303...what are the last three codes?
P0507 Idle Air Control at Stop - Above Limit
- Leaks in intake air system
- Leaks in crankcase ventilation
- Throttle adjusting unit faulty
P0300 Misfire detection - checksum error
P0301 Cylinder 1 Misfire Detected
P0303 Cylinder 3 Misfire Detected
All point to an air leak.
One thing that I failed to mention whe I originally posted this thread, was that about a week ago my wife had the car close to empty (range was about 12 miles left). When i put gas in the car, i left the car running (which I usually do - though I bet that it is a stupid idea after reading above). I noticed some black smoke coming out of the exhaust, with some rough ideling. The car stalled and I had to turn the starter 2-3 times before it started (it ususly starts the first time). It idled a bit rough on the way hom but then is seemed to be OK. there was no engine lights issues.when I rode the car home. The engine liight with the above codes came on 1-2 days later.
Is there any connection here or just a strange conicidence.
I would recommend replacing the EVAP flow control solenoid with the updated unit, clearing all codes and monitoring. There is a DYI on the forum for replacement. It's rather straight foreword to complete. The valve often starts with an intermittent failure and would account for all of your symptoms.
