issue: intermittently, acceleration will suddenly become VERY slow no matter what gear i'm in or how fast i'm going. to imagine what's happening, think about being in 6th gear while going 20mph and then stomping the pedal. VERY slow to accelerate, right? well that's what starts happening...in ANY gear...at ANY speed. even if i come to rest and start again, even in 1st gear - same thing. VERY slow. (i.e. it seems it's the "maximum pedal value is limited to 30%" below). the only thing that clears it is turning off/on car. and i should mention that, if the issue does arise on a drive, i think it's after driving normally for awhile, then coming to a full stop, like at a light or something - after starting back up, the problem is all of a sudden there.
so i have a durametric and this is the fault:
P2126
Throttle valve adjusting unit – potentiometer
NOTE
When a fault is detected, the system is in stand-by operation mode in pedal sensor, i.e.:
---Maximum pedal value is limited to 30 %.
---Dynamism is limited.
Diagnostic conditions
---Supply voltage 10 V ... 16 V
---Engine start
Possible fault causes
---Open circuit, short circuit to B+ or short circuit to ground in the sensor line to potentiometer 1 or 2 of the throttle valve adjusting unit
---Throttle valve adjusting unit faulty
---DME control module faulty
solutions?
i ordered a throttle body and will replace (easily) this week, but arent there also potentiometers in the accel pedal too? there is a guy on rennlist now who replaced both throttle and pedal, yet STILL has the issue.
thoughts?
I would start by cleaning the throttle body with a good commercial throttle body cleaner.
Also, remove and clean the throttle body electrical connectors - using a good electrical contact cleaner.
Then reset the codes and see if it happens again.
thanks loren! i am getting good at replacing DIY's but dont have much experience with cleaning DIY's. can you recommend a good cleaner for each, as well as a brief how-to on how to clean the TB itself? i just dont want to spray anything where i'm not supposed to.
Throttle body
http://astore.amazon...tail/B000M8PYO2
Electrical contacts
http://astore.amazon...tail/B003NTQCA2
No tool kit should be without these and MAF cleaner.
