Easiest way to remove most coolant
Hi , I plan to change out my coolant and just want to find the easist way to do that.
I plan to drain from the coolant drain plug on the engine, then disconnect the lower coolant hoses from both radiators.Would this work? Total capacity should be about 6 gals and I hope to get at least 4 gals out with this method.
TIA
  • Replacing the serpentine belt, too?
Already did but thanks:) Car is an '03 with 55k miles. Thinking whether to replace the idle pulleys. No free play but some gritty sound. They are expensive for a pulley...
