Oil pan compatibility
I just found out about the much lower torque requirements for the LN Eng magnetic drain plug and realize I may have stripped the threads on the last oil change before winter bedtime.
I could feel the torque wrench start to slip, stopped right away, but did continue putting oil in the engine. No leaks so far. But now I'm concerned the threads in the pan have been stripped, rather than the bolt. There's a pan available from an 2004 2.7. Any reason why that wouldn't fit on a 2001?
