I have noticed on my 996 Carrera 2S that there is a wire attached to the engine cover lock that enables the lock to be opened manually. This wire runs from the lock towards the passenger side (UK car and left side when looking from back) and then disappears behind the rear light block. It is not a botch job, but looks like a manufacturer's fitting that can be used when the electromagnetic switch is not functioning as it should. It works in the same way as the fuel filler manual release that is within the door frame. Before I start taking things apart to find the other end, where is the other end of this release wire? I suspect it's behind the rear wheel splash guard above the exhaust.Any guidance would be helpful.RegardsH
I have also found the front wire, for the boot, which is below the headlight tray. I have now moved this slightly to make it accessible from an external location.
H
