Electric Mirror Switch Controls Both Mirrors :o(
Hi Guys
On my 4.5 S Cayenne when using the elctric mirror switch if you select passenger side it works a-ok, but if you choose drivers side that also works ok - but adjusts BOTH mirrors at the time time (very annoying!!)
Anyone come across this issue before??
Hi Guys On my 4.5 S Cayenne when using the elctric mirror switch if you select passenger side it works a-ok, but if you choose drivers side that also works ok - but adjusts BOTH mirrors at the time time (very annoying!!) Anyone come across this issue before??
I've currently got this issue on my CTT. I'm assuming that it is the switch that is at fault.
On the same subject. On my passenger mirror I can see a wire (with female spade connector) just poking out from the side of the glass which is obviously not connected to anything.
I assume it's for the heated element, and I want to pop it back on. Is the glass easily removed to get access to the rear? I'm a bit worried about breaking the glass.
  • 2 months later...
my heated mirror feature is not working (for both sides).  Is there a fuse for that?  or is it a switch issue?  they fold and adjust with no issues.  they just don't heat.  Any advice is appreciated.
Roch.
Roch, Any update on your problem?  My mirrors don't heat either??
