I have an '04 C2 and want to start my own maintanence records so I am having the coolant flushed.
Can someone comment on whether it is OK to use Audi coolant as they are much closer to me than the dealer. Replies are appreciated.
Loren I did review the DYI in the forum but there was no mention of approved coolants. I should have searched more extensively.
Thx for your response.
Take your time in taking air out of the system if you are not using a vacuum pump. A trick is to park the car on an incline, front end towards the bottom, and open the expansion tank for a while so all air bubbles come out.
