Does anyone know the part number of the throttle nut that goes on the throttle rod under the hand brake/throttle linkage that allows the manual throttle linkage to engage with the plastic pc to control the idle up.
Loren thanks for the quick reply, however I need the part that is on the linkage rod that moves in line with part 20 of your diagram. This part is not shown on you diagram.
  • 3 months later...
That would be pretty simple to make. Drill a hole through the center of a ~ 1/2 - 5/8" dia rod, dosen't even have to be exactly on center. Drill and tap a hole in the side for a set screw.
I was just looking for oem, put have not found a new one. Have not looked for old, however was going to make one. Thanks
