looks too yellowish to me!
Anyone tried HID matching blue version from Osram or other brand?
Does it make noticeable difference? Any recommendation, please.
The problem you will run into trying to match the litronic light color is that it is not pupleish-blue like on the BMW's. I thought this was discussed in depth over on 6speed about replacing that light. I have tried but got tired of matching blue bulbs that when not illuminated that reflect blue in the housing and look very RICER. Not my cup of tea.
jinijazz,
you're right. the city light is yellowish. You need to buy the Philips Blue Vision H6W bulbs. they match up really well and reduce the yellowish tint that it casts on your litronics.
you can't get them in the US as they come from the Europe.
They don't make your headlight look bluish either as they are pretty small.
If you're interested, I have a extra pair in the package still. otherwise you'll have to order them from the UK.
That is the light housing on the 02+ 996. The 996/986 litronics are a bit different than that. Does the 996 and 986 litronics even use the same bulbs?
Thanks for the link, MA$E.
The person on the link said Philips is NOT yellowish at all, but the same person later said it IS still yellowish. So is it better, but still yellowish?
hey Jinijazz,
in my opinion, they are still a little yellowish, but def better than the stock ones.
you can really notice the difference when you are about 10 feet away form the car.
The old ones make your xenons look pretty yellow.
with the philips bulbs, not so noticible.
let me know if want this extra set to save time and shipping from the UK.
$25 shipped to you.
Thanks for the offer, MA$E.
Fortunetely I just got used pairs from local Boxster owner.
FYI, AMBulbs.com told me they are working on better city light bulbs(whiter but not blueish reflextion when it's off) .
Thanks for help!
okay the reason for litronic bulbs are blue is because that the bulb base which all cars with HID are equipped with are labeled d2s. after 200 hours of use from the time the bulbs are new, it tends to "colorshift".
New D2S bulbs from philips are yellow at start, until around 150 hours of use it goes through a color change to pure white . then bluish white.
Buying BLUE halogen bulbs kills output and you can barely see at night. its like putting a blue lens through a flashlight and then go out into the woods to find a coin on the ground. You cant see crap. All of you need to learn up on High intensity discharge technology and make an investment of having "litronic" dont know why porsche calls it, its basically a special name instead of HID or xenon.
and again to reiterate on the bulbs. Philips are YELLOW when brand new and over time it changes color to whitish then bluish white. for Osram bulbs it puts out a pinkish white color after 200 hours
jinijazz,
i have the philips 3400° bulbs for my headlights and parking lights (W5W). they are noticeably whiter than standard halogen bulbs but not as white at litronics. they do look better than the standard parking bulbs with HID lights though as i put them on my other car.
i've seen that philips now has 4000°K bulbs. those should be whiter. haven't tried them but i will when mine burn out.
