Total electrical failure - 1998 Porsche Boxster
-Opened the door: Door light on and overhead light on (normal)
-Placed key in the ignition: Dash lights on, all looks good.
-Turned engine over: Did not immediately start (not unusual... battery charge seemed quite normal)
-Turn key back to off position to try again...
When I turned it "On" I had no electrical power to anything:
-No headlights.
-No overhead light.
-No dash light.
-No heater fan.
-No door lights.
-Alarm is also not flashing its red light.
-No windows.
-No locks.
Does anyone have any idea what this could be?
I will check the battery when I get home to make sure there is no corrosion and terminals are secure. It just seems very odd that all would be well and then suddenly, for no apparent reason, I get literally no electrical power in the car.
I did a forum search on "bad ignition switch" and pulled up a lot of documents! Let's assume the battery is good. What am I looking for about the ignition switch? Replacement?
I just dont understand what the ignition switch would have to do with all of the power in the car... literally nothing works. Nothing at all.
Thank you all! I will post back once I have the answer to the battery.
Edited by Shawn Booze
The only way to really test the battery is to remove it and take to an auto parts store that does load testing. They should also perform a specific gravity test on each of the battery cells.
If your battery is 4 years old or older I would replace it anyway as you living on borrowed time.
