Hi There,
I bought a 1999 996 Cabriolet manual 6 speed that had been stolen trashed and recovered, minus the immobiliser.
The car is a UK import to Australia VIN is WP0ZZZ99ZXS644456.
the ECU BOSCH # 0 261 204 605 / 996.618.601.04
I understand the immobiliser is a M534 model, My question is what is the immobiliser number
I need to get my car running and then start a restoration of this car.
I have spoken to several suppliers in the UK however none of them will send me the correct and matching
immobiliser part number.
They say we don't have the matching part, leaving me back at square one!
Can anyone please provide me with the part number?
Best regards,
Neil
Edited by neilcerche
:welcome:
For your VIN you will need: 996 618 260 06 (M534 version)
It will need to be programmed by a Porsche OPC using a PST2 or PIWIS tester.
Thank you so much Loren for your prompt reply.
Can I buy a used one from UK with keys?
Is it possible for this to be programmed more than once?
Will it have to be reprogrammed to my existing ECU?
People tell me I need a full set as being sold as plug and play?
Are there any traps to avoid with this?
Another option I believe is to have the immobiliser bypassed altogether as per the racing fraternity?
Best regards,
Neil
Yes, but you can likely reprogram it to use your keys (you will need the unique 40 digit ID number for each of your keys).
Yes, with the proper codes and keys.
Yes the two work together - so the programming affects both.
As I said above you need working keys, IPAS codes (available from the OPC), and your cars unique 40 digit ID number for each of your keys.
Porsche race cars use a completely different DME (ECU). Unless you plan to use the car only on the track I do not recommend this.
Sorry Loren, but the Alarm Control Unit can only be programmed with an immobilser code once. However, if you know the immobiliser code for the donor ACU, you could have the DME programmed with that code, so that the units match. You would need the IPAS codes for both vehicles.
Hi Loren and Richard,
Thanks again for the valuable information.
I have a British supplier who is really trying to help with my dilemma.
Can you read his email and tell me which ECU kit is the right one for my 99 996 Cabriolet manual?
My car is a UK import to Australia VIN is WP0ZZZ99ZXS644456.
Dear Neil
I have just removed an ECU set from a 1999 996 today, VIN # WPOZZZ99ZYS602402. Barrel & housing with key included in price. Door handles/locks no problem.
Immobiliser number M534 996.618.260.06
ECU number 996.618.605.00 Bosch 0261 204 790
All units are coded together. ECU number different but it won't give you a problem. *****
Also removed a Boxster ECU set today off a 98 model. Alarm number is 996.618.260.04 M534, ECU number is 996.618.601.04 (Bosch 0261 204 605) VIN # WPOZZZ98ZWS604904.
Quite bizarre how all numbers are very similar between Boxster & 996 models.
Also got a couple of sets of 996 ECU sets from 99/00 models with the following numbers:
Immobiliser 996.618.262.00 & ECU # 996.618.605.00 (Bosch 0261 204 790)
Immobiliser 996.618.260.06 & ECU # 996.618.605.00 (Bosch 0261 204 790)
Thanks for reading this lengthy post, however I really need some expert advise!
Thanking you in advance.
Best regards,
Neil
You will need to make sure that the DME comes from a MY1998 or MY1999 Carrera 2 (which has mechanical throttle) rather than any Carrera 4 (which has eGas), and definitely not from a later Model Year. The Alarm Control Unit and DME can be re-coded with a PST2 or PIWIS to suit the model variants, BUT they cannot be re-programmed for the fuel map, immobiliser code, or for new keys. A Boxster DME will have the wrong fuel map.
The key blades can be swapped from the original car, so you won't need the locks. It is the immobiliser pills and radio remotes from the donor car which you will need to use with the DME and ACU set. Bear in mind that if you don't have the IPAS codes from the donor car, you won't be able to get a new key head programmed to it.
Here are the option codes for your car, btw:
WP0ZZZ99ZXS644456
MI NUMBERS DESCRIPTION
I029 Standard chassis
I211 Licence plate holder version 3
M061 Version for Great Britain
M071 EU country version
M130 Control and indications in English lettering
M197 Stronger battery
M220 Locking differential 40 %
M222 Anti-slip regulation (ASR)
M224 Automatic limited slip differential
M271 Door mirror -aspherical- driver's side,
electrically adjustable and heatable
M273 Door mirrors,
M274 Vanity mirror illuminated
M321 Radio "Porsche CR 22"
M335 Automatic seat belt, 3-point,
rear
M338 Rear-wheel drive
M369 Standard seat, left
M370 Standard seat, right
M413 18-inch Turbo-Look wheel
M421 Front cassette compartment
M439 Electrical hood operation
M441 Radio preparation
M446 Concave wheel centers
with full-colour Porsche Crest
M466 Rear foglamp, right
M480 6-speed manual transmission
M490 -MY 01 sound system
MY 02 sound system Harmann analog
M492 Headlamps for left-hand traffic
M534 Theft security system
M536 Alarm siren and tilt sensor
M539 Mechanical seat-height adjustment, left
M540 Mechanical seat-height adjustment, right
M550 Hard top
M562 Airbag, driver's side and front passenger's side
M563 Side airbag
M566 Front fog lights, white
M567 Windscreen tinted, upper part darker coloured
M573 Air conditioner
M581 Center console, front
M590 Power lid locking
M602 Raised stop lamp
M605 Headlight levelling system
M651 Electric window opener
M657 Power assisted steering
M685 Rear seats, split
M689 Preperation of cd autochanger
M936 Seat covers, rear, leather
M981 Leather equipment without seat covers
M983 Seat covers, front, leather
Edited by Richard Hamilton
Hi All,
It turns out I have been hood winked !
After fitting the new immobiliser and had everything encoded the engine will not fully crank as it has been blown up!
I am now up for a rebuilt engine for the car.
Can anyone recommend a good source for another engine for a 1999 996 3.4L 6 speed in Australia, or elsewhere for that matter?
I think it prudent to get an engine with the IMS fix applied, am I right on that?
How much is this likely to cost?
Best regards,
Neil
