fog lights for 911/930
sprocket
Hi folks,
I've just purchased a 1980 911 Targa SC and she's a beauty.  It appears to have the Ruf 930 body conversion.  It is missing it's fog lights and I was hoping someone could help me track some down or at least recomend some that are compatible.
Here is the pic of mine with the openings and I've attached a photo of a 930 coupe to show the similar body with fog lights.
Thanks to everyone in advance.
Roch.post-52115-0-18437000-1411609773_thumb.jpost-52115-0-61988300-1411609801_thumb.j
Had the same front lower valance. Typically, fog lights from the early eighties SC/turbo fit. OEM is too expensive. Try Hella
http://www.pelicanparts.com/catalog/SuperCat/0796/POR_0796_ELLITE_pg8.htm#item28
Installation is sometimes an issue as the lights hang from above and the valance may not have adequate return inside the top of the hole. May have to remove valance as fiberglass one in.
Cheers,
Johan
Hi Johan,
I actually bought the exact lights you just highlighted....They are too big and don't fit in the opening.  I guess I will just have to find an aftermarket set that will fit the opening and hope for the best.  What I thought would be easy is turning into a headache!  Thanks for helping Johan.
Roch.
