Hello... Again...
My PCM 2.1 on my 2005 Cayenne Turbo has on the information display, no satellites [Please check pic].
post-41858-0-47076800-1430347267_thumb.j
Firmware for both PCM and Navi DVD unit were upgraded, but no satellites. I checked it with the Durametric Pro but doesn't seems to fix the issue. Also I checked the connections from the antenna on the rear spoiler through the NAVI unit and it seems ok. I opened the GPS antenna and cleaned contacts overall, but still the same zero satellites results...
Any ideas? Thanks in advance!
Did you solve your problem?
No. I did the 148 & Fuse trick. Didn't work. I bought the GPS Antenna and waiting for its arrival...I'll notify whatever results when I install the new antenna...
Thanks anyways :thumbup:
Finally SOLVED! :cheers:
It was the GPS Antenna! I replaced the unit in the Rear Lid Spoiler, but nothing! So I proceed to apply the 1-4-8 code and VOILA!  :jump:  :thumbup:  :cheers:  It worked!!!
post-41858-0-46632800-1431389903_thumb.j
So I guess that if you have NO Satellites and applied code 1-4-8 and still no Sats after check connections, then you got a bad GPS Antenna unit.
Finally if you install a new GPS antenna, then apply code 1-4-8 on the PCM unit to reset and PCM to recognize new GPS Antenna. Here are today's picture with finally NAVI Unit fully working. I still got the warning triangles on the SW versions, but at least I can use the NAVI now!
post-41858-0-63888100-1431389924_thumb.j
Thanks and hope this could help others....
SithPitt
SithPitt
Good to know - thank you.  Can you provide the part number for the antenna and the cost please
Thanks, Simon
post-41858-0-98702200-1431467964_thumb.j
SithPitt
Thanks, Simon
Ok Simon, here all go: :jump:
Pictured below is the GPS OEM antenna...
Here's the Volkswagen Part Number [7L5 035 507 A] as seen on the GPS metal base sticker....
post-41858-0-74581200-1431468053_thumb.j
Here's the Porsche Part Number [955.647.107.01 or 955 647 107 01] as seen on the box from manufacturer....
post-41858-0-86139500-1431468134_thumb.j
I wrote down the numbers because Images, sometimes, are not displayed... I bought this item at www.ecstuning.com for around $79.00 [not including Shipping & Handling]
Hope this helps better to everyone in the future...
SithPitt
That is the Antenna for GPS w/o Satellite Radio.  If you have XM/Sirius then you need part 95564711701 which combines the GPS & Sat Radio into one antenna.  Congrats on the repair.
Well that's something that I didn't know, but it's a good thing to know... Mine doesn't have Sirius :thumbup:
And BTW thanks for the congrats :jump:
  • 9 years later...
SithPitt
Hi, where is the location of the GPS antenna ? is it in the rear spoiler (rear wing ) ?
tq.
