2002 996 rear Bose speakers
According to my Bentley manual, the Bose units used between 1999 and 2001 are different to the ones between 2002 to 2003, and then it 2004 it changed again and added MOST. In my car, the rear speakers are wired in parallel, which means that there is no left rear and right rear, despite there being a physical left rear and right rear speaker. When I examine the connector going to the amp inside the frunk, the rear speakers have already been bridged. Does anyone know where this actually takes place? My guess is that it would be in the dash somewhere.
Thanks Loren. I didn't realize that the location of the connection on the wiring diagram indicated where it was physically. Well I guess that I'd have to run wires from the speakers, which is probably more work than I'm willing to do.
Thanks Loren! You are awesome. I have wanted to know the answer to the same question for quite some time.
Thank you for everything you do for RennTech. Seriously, you are such a valuable asset to this forum, no matter what year/make/model and, you take the time to give to others which is especially kind and generous.
Julie
