I have a 2010 panamera turbo with 56k miles with a tuned file with 622 hp; use as my daily driver; been running great and no issues; then today after leaving appt I start and starts idling very rough; no lights come on; I was low on fuel yet no indicator light; drove to station fine and filled up.
Ran some more errands and no issues; then leave last one and as I'm driving stop and go engine comes on, psm light and start/stop disengage light all appear; engine running very rough.
Pull over and turn off and restart; roughness goes away after couple minutes and I drive back to office with all the lights still on; leave office later and all lights are off and runs fine.
Any ideas would be appreciated
post-59175-0-35552400-1443669335_thumb.jpost-59175-0-62200700-1443669383_thumb.j
attachicon.gifused-2010-porsche-panamera-4drhatchbackturbo-811-13163798-5-1024.jpgattachicon.gifused-2010-porsche-panamera-4drhatchbackturbo-811-13163798-8-1024.jpg
You need to get the car scanned with a Porsche specific scan tool (Durametric, PIWIS) to find out what codes it is throwing; without that anything would be a guess and not the basis for action steps.
Well they jjust performed the 60k service, changed all the spark plugs which were original; it did same thing again then check engine went off and runs fine.
They said next would be to replace coil wires, yet they inspected all and no cracks; maybe a clogged injector; going to run a couple tanks with techron and see if that helps.
