2014 Cayenne Diesel. I've searched extensively and can't seem to find an answer.  All the hits were for older Cayennes.  The placement of the floor jack, I'm assuming is the same place as the tire jack (someone please correct me if I'm wrong) but can't seem to get an answer for the placement of the Jackstand in the front.
Also, would a single 3-ton stand be sufficient for raising one wheel?  From what I've read, the ratings are for using 2 stands, and a single stand may be only 1/2 the rating at 1.5 tons, which may not be enough for a 2-ton+ SUV.
Thanks for any advice.
Ron
  • 5 weeks later...
Just off the top of my head - and assuming the Cayenne is close to balanced 50/50 weight distribution.. lifting one wheel will only need 1/4 of the weight capability of the entire vehicle. So a 2 ton vehicle - a 0.5 ton jackstand should be sufficient to support the load normally carried by one wheel.
