To fully test the system, you need access to:
  • The terminal lug on the back of the alternator where the primary wire attaches (for checking diode ripple).
  • The alternator primary wire itself (for an amp meter to clamp around and measure current draw).
If this is outside your level of comfort, I'd suggest taking it to a shop to have it tested.
Not so much the comfort level, but maybe Im not understanding the simplicity of access  :huh:
Can I get to the terminal and primary wire just by removing the tire and wheel well liner?  If not, and you have to go through the first parts of the alternator removal process, I dont see how you could do that, hook everything up, and still have the engine run.
Edit: Im sure your way is much more thorough and appropriate, so dont think this is a counter argument :cheers:   I just read the instructions that came with the load tester.  It says to just hook up to the battery terminals and when you rev to 12-1500rpm it will run a charging system draw to test the alternator.
That method is a bit more basic and will show the voltage response, but not validate the diodes functions or provide an amperage output value.  For simplicity, try their methodology and see where you are before digging in further.
Will do.
The main thing r.e. comfort is that its a daily driver and I dont have a ****kicker 3rd car anymore, so anything that could take more than an afternoon needs to be a weekend plan.
I did drive all over today totaling about 100 miles with no funny business other than the air suspension not being able to drop at 80.  I didnt want to push my luck though so I left the A/C off even though it was hot today  :lol:
Edited by 5thlilpiggy
Did the alternator test, and it read at 13.9 with the Good light lit the whole time.
Swapped out the battery.  The old one was a 730CCA, so probably low end.
Went for a drive around the block and all was fine.  Got back to the garage and tried to lower the suspension...workshop failure.
Re-started car, selected terrain level and it successfully went up and looked even.  Selected normal, and it successfully went down and looked even.  Selected low, and got workshop failure.  Seemed like there is a slight tilt to passenger side.
Restarted again, hit raise, and all hell broke loose.  RPMs hunting between 300 and 1200, CEL on.  Turned off and ran the codes.  Had DVE amplifier, a throttle code, and misfires on 4, 8 and random.  Also had DME com error in the transmission and steering angle sensor errors in a couple of other modules.
Cleared them all, waited a few min and started again.  Had normal idle, so I went around the block and all was fine except now I couldnt raise suspension because it said the compressor was charging. The compressor was definitely on when I raised to terrain the first time, but didnt seem to be on when I got back this time.
Is my DME going out?
I don't think it is necessarily your DME, but several of those faults look to be communications issues on the CAN bus network.
Could I have caused a canbus issue with my work in the serpentine and vacuum leak troubleshooting?
At any rate, that sounds like I would need a durametric or PIWIS to diagnose?
Went to work with no codes. Raised to terrain and lowered to normal with no issues. Did not try low yet.
Do you know why it can go down, but only to normal level?
A Porsche specific diagnostic tool is always the best approach as it can seen things a global OBD II system cannot.
I have not idea why the car's level control it not working properly, but it also may need recalibration.
Update:
Drove about 200 miles since the last post with no funny business out of the PSM or DME.
Went over 80 today to give the air suspension a test (I had refrained all week cause I hate seeing the warning for half the drive) and it went to Low quickly with no trouble.
Big thanks to to JFP for all your help thus far.  If you want to PM me your paypal Id be happy to toss you some beer money.
Until next time...
Update:
Until next time...
Thanks for the offer, but it is completely unnecessary.  Glad you got it sorted.
Thats cool, Ill make a site donation instead.
Im not ready to go that far, but thanks for the optimism  :D
And thank you for your continued support of RennTech :thumbup:
