Runs perfect , drive in hot day 85+ degrees, stop for 30 min or longer and does not want to easily start (takes 10+ seconds of cranking - seems to starving for fuel)
Replaced fuel pump, check valve and fuel accumulator.
Didn’t cure the problem.
Any expert suggestions??
Thanks.
Are you sure it is starving and not flooded?
A leaking cold start valve will cause starting issues.
Try starting with the accelerator pedal to floor...
I don't smell gas and stepping about halfway on the gas pedal helps it start .
Yesterday after starting for the first minute or so it's rough and doesn't want to idle nicely, that started just yesterday. After couple of minutes it's perfect again .
  • 8 months later...
Quote
could be the altitude.  adjust the fuel injection if possible.  check start without air filter.  happened to me in my 79 SC up in Sierra Nevada's.  What year is your car?
