Location of 996 secondary relay/fuse box?
Hi All,
Could someone advise the location of the secondary relay box?
I am repacing a faulty Secondary air pump, and want to check the fuse and relay before I install the new one.
I read that it's behind the rear seats but have not found it so far.
Thanks for any assistance.
Steve
If you have the bose speaker on the rear shelf, you'll have to remove that and its brackets first. Then pull the carpet up as previously mentioned. You'll see two metal plates, the right side has the relays. Easy process, minus fitting back there.
Sent from my SM-G920V using Tapatalk
  • 2 years later...
