After replacing the top, the top dash warning light is illuminated and the top will not function.  The ignition is energized and the parking brake is applied.  I manually depressed the microswitch with no luck.  Any ideas?
Exact model and year of your car please?
Is the parking brake on? My microswitch failed and the parking brake light was not. Sprayed cleaner on the switch and it has been working since.
