While driving home tonight ive noticed that when i break the radio flicks off for a second also the headlight flick at the same time.
Also not noticed if i turn on the heated rear window it has the same effect on the radio.
Then lastly got out and my remote locking on the key has also stopped working.
Any ideas?
What was the voltage reading in the dash voltmeter? How old is the battery?
Does the LED on the key fob light up when you press the buttons?
4 hours ago, captain caveman said:
Went out to the car this morning turned the key dead nothing at all.
Popped the cover off the battery to find the earth lead had come off!
So for once a quick easy fix.
Check the +ve lead as well - you don't want that to bounce off as it could cause other problems such as voltage spikes.
