Hello
i have problem with my cayenne s 955 2004
codes:
P0139 - O2 sensor circuit slow response (bank 1 sensor 2)
P0300 - Random multiple cylinder misfire
P0301 - Cylinder 1 misfire detected
P0303 - Cylinder 3 misfire detected
Sometimes i have code from camshaft position sensor
Rough idle and vibration
What is it ? I have all new spark plugs and coils, cleaned throttle..
Edited by Dawdoo
:welcomeani:
The number one cause of misfires on the early Cayenne's is ignition coil failures.
If you remove and measure the resistance (in ohms) of a misfiring cylinder and know good cylinder you will see a huge difference in resistance.
If the car has not had the coils changed in the last 2 or 3 tears then I would change them all to the latest version.
