I am installing a boost gauge and have found plenty of switch 12v fuses but cannot find one that only turns on with the lights on. I have one wire to the gauge that works as a dimmer. Anyone know where I could tap into a line that activates with exterior lights on.
Hey loren,
  I actually figured it out on my 2003 cayenne turbo. I tapped into pin 10 on my headlight switch which is the illumination wire for the switch.
