P0503 Vehicle speed sensor - no signal/above limit value
Possible cause of fault:
- No signal or faulty signal from PSM control module
- Rear right wheel speed sensor faulty
- CAN data bus faulty
- PSM control module faulty
Fault code 1682 - Speed signal, rear right wheel
- Signal from PSM control module does not correspond to expected signal (please read out fault memory)
- Signal from PSM control module does not correspond to expected signal (implausible signal)
I would check the right rear speed sensor - replace if needed - then re-test.
Hi I have something similar but different
I have the psm light and phc light come on instantly
ive researched and checked the wiring near foot LHS and I actually didn’t find any previous joins like some others I’ve seen corroded, my wiring was dry also, I also researched that it could be the brake light switch but my lights are working and like someone else my switch isn’t where it should be, I did find that someone asked the same thing about where his switch is but the answer was written on a different post which I couldn’t find, if someone could help it would be much appreciated
Id like to ad that I used my obd but those faults won’t show so I can’t get a computer reading to help me
thanks
Stevie G
