1999 996 Carrera, tapping sound, low oil pressure
Hi everyone I have a 1999 996 Carrera cab, which today suddenly developed a tapping sound and engine light came on, idle speed dropped to 500rpm with almost no oil pressure at idle, limped home, help anyone, could a failed coil cause this? Mine look cracked and in pretty poor condition.
Coil should not create tapping noise. It would help if you can upload a sound clip.
In the meantime, I would suggest changing out the pressure sender and replace all the coils (and spark plugs too while you are there). Then check the oil filter and drop the oil pan to check the oil pick up tube.
