  • 2 years later...
Was a solution found for this problem?
I have a 2000 Boxster S racing car which I have transplanted a 2002 996 3.6 engine along with a change from the 7.2 dme to the 7.8, and I am having a very similar problem.
As a racing car, I have done most of the same modifications, so hope this is down to something that has been removed and I need to put back to enable the dme to run adaptation.
On the Durametric I get the following adaptation values with no change at all:
.- Adaption range 2 (FRA) bank 1 = 1
.- Adaption range 1 (RKAT) bank 1 = 0
.- Adaption range 2 lower (FRAU) bank 1 = 1
.- Adaption range 3 uppper (FRAO) bank 1 = 1
.- Adaption range 2 (FRA) bank 2 = 1
.- Adaption range 1 (RKAT) bank 2 = 0
.- Adaption range 2 lower (FRAU) bank 2 = 1
.- Adaption range 3 upper (FRAO) bank 2 = 1
