Carfax shows the following:
At 3 years old and 12k miles: Camshaft(s) replaced/repaired; Engine cleaned; Engine removed to complete repair; Front crankshaft oil seal replaced
At 6 years and 29k miles: 30,000 mile service performed; Axle bearing replaced; Clutch release bearing replaced; Valve cover gasket(s) replaced; Engine cleaned; Front crankshaft oil seal replaced
Transmission checked; Transmission removed and reinstalled
Seller says car had ims done in 2013.  Car now has 49k miles. Thoughts
Also,   car has large rear GT3 style spoiler, doe s that prevent air flow into air box?
Personally, I'd like to hear why the engine needed the front oil seal replaced twice, and why it needed new cams.  Very low probability repairs that rarely occur, and they both occurred on this engine.  Strange...………..
Ditto.
Will likely never know. Here is service history from Carfax (no service reported after 2010, car has 49k miles now.
04/06/2005
5,189
Brumos Porsche
Vehicle serviced
02/08/2006
9,260
Brumos Porsche
Recommended maintenance performed
03/16/2007
12,661
Brumos Porsche
Recommended maintenance performed; Camshaft(s) replaced/repaired; Engine cleaned; Engine removed to complete repair; Battery replaced; battery charging system checked; Front crankshaft oil seal replaced
05/11/2007
12,685
Brumos Porsche
Computer module replaced
05/29/2007
13,742
Brumos Porsche
Front door trim panel replaced/repaired
Front window repaired
04/13/2009
>29,532
Tom Bush Autoplex
Vehicle serviced
03/15/2010
29,532
Brumos Porsche
Axle bearing replaced; Clutch release bearing replaced; Valve cover gasket(s) replaced; Engine cleaned; Front crankshaft oil seal replaced; Transmission checked; Transmission removed and reinstalled
04/06/2010
29,856
Brumos Porsche
Front wheel bearing(s)/hub(s) replaced
04/06/2010
32,005
Porsche of Orlando
Maintenance inspection completed
Tire condition and pressure checked
Wing/spoiler replaced/repaired; Horn replaced; Body electrical system checked; Brakes checked
