Cayenne DTC help P053C & P0456
Hello,
I have two DTCs on  my 2011 Cayenne that I need advice about. The codes are P0456 and P053C. The car runs fine. Are there any preventative repairs I should undertake?
Edited by Loren
rotated images
P053C
Intake camshaft adjustment, bank 2 after cold start I during catalytic converter heating measure
Possible fault causes
- Engine oil pressure too low  (e.g. oil thickening, wrong oil quality, oil pressure control or oil pump sluggish/stuck)
- Solenoid valve for hydraulic camshaft adjustment sluggish/stuck
- Camshaft adjustment sluggish/stuck
- Intake camshaft sluggish/stuck
P0456
Tank system leak
- Tank cap loose/does not close (properly)
- Tank cap leaking/faulty
- Vacuum system leaking (See K 1)
- Vacuum pump faulty
- Tank vent valve (TEV) mechanically faulty (does not close (properly))
- Leakage diagnosis pump fresh air side constricted (dust/dirt)
- Internal (diaphragm) or external leak in leakage diagnosis pump
- Fuel tank system (with hoses) leaking
