My 2009 c4s has a leak on a connection to the water pump (see picture). I’ve put in UV dye and have confirmed it is at this joint. I’ve tightened the bolts a little (moved easily) but I’m still getting a leak. What’s the torque for these bolts? Is there a gasket? I had the pump changed 30k ago so assume they put in a new gasket. Any other suggestions?04545b63a79fd4565f53fa5158263871.jpg
Sent from my iPhone using Tapatalk
