09 Cayenne S Fault Code 1749
While checking another issue I checked all systems for error codes and found Error Code 1749- Tiptronic switch on steering wheel down under Steering Wheel Electronics using Durametric Software.  Steering wheel shift switches are working fine.  I've tried to erase the code to see if it comes back, but it doesn't erase. I have researched it and don’t seem to find anyone that has posted about this error code.  Anyone seen this issue/error code before or have any recommendations?
Thanks in advance for any recommendations.
Loren, thanks for the quick reply.  One other time I had an issue that I could not find information on a code, Durametric transposed the numbers.  By chance can your list of codes be sorted by system?  If so can you send or post the tiptronic shifter codes? If not I won't worry about it.
