31 minutes ago, A Corn said:
Can I use 16" tires on the 996 without screwing up the speed senors?
I seriously doubt 16 inch wheel will clear the brake calipers and rotors on the car.
19" should fit, assuming the tire size is not excessive.  As for the speed sensors, they should work fine, but will only be accurate if the 19" wheel/tire combination has the same rolling circumference as the current tires.
