Thank you both…I should clarify I don’t have the code.  The airbag light was cleared a couple times but returns after very short while 10-15 minutes.
This has been going on for years and 2 ignition switches.  I’ve adapted to live with it but it does bother me that 2 Porsche shops tried to eliminate and were unsuccessful.
Dealership said would swap switch to cancel fault light at a lofty $2k.
Will verify buckle connection to floor. Appreciate your assistance!!
I had a similar issue when I replaced the seat belt buckles the airbag light will stay on even if you cleared the codes with any diagnostic tool "Autel, Durametric...etc". However, I had to recode/reprogram the airbag unit with Porsche Tester and it solved my issue.
