Anyone know why my replaced HVAC display has the incorrect graphics. The temp is not shown as increment bars. It shows a number(temp in Degrees) then takes away a line at each lowered increment. See pics. You can see the #8 disappearing as I toggle down on the temp. This is the 2nd display I've tried, both do the same. Loren mentioned the temp sensor which is attached at the bumper....pointy black sensor. Any info would be appreciated. Thanks V
Edited by vza
This is the part off of ebay. Not sure if that would help. Thanks V https://www.ebay.com/itm/266159555586
Also purchased Allway part from Amazon had the same results. They're pix show the HVAC with 'Auto' climate control my unit dosent have auto, maybe that's the issue.
Edited by vza
Do you know if it would effect any HVAC controls if I left in the display with the incorrect graphics.
