Hi 911 carrera 4 2002 the driver seat is stuck !! Can’t go forward or backwards I can hear the motor the lower or higher options works. Plz help I’m stuck with no leg room. Thanks
Had the exact same car and the cause was the drive cable needed to be replaced.  Agree with Loren though, check that first and if that is not the case you should be able to inspect it.  I unbolted the passenger seat from the floor to fix it, if I recall they are torx.
Edited by Silver_TT
