I am having a tough time trying to figure out how this forum posting works. I have tried several differant things and I hope I'm not just making a mess of things. Be that as it may, I am just looking for some help with my radio code. Here is what I have.
2001 Boxster
CDR-220
Becker 1
Type 4462
24/99
15085036
Please help me.
Thank you
Try 5441
or
5439
Thanks for the quick reply.
Neither number worked so I went up 2 numbers to 5443. Still didn't work so I locked out for an hour.
If the radio is a CD-220 and not a CDR-220 would that make any differance?
Once I am alowed back in I plan on dropping down 2 numbers unless you have some other suggestion.
Thank you,
Hal
CD or CDR makes no difference.
Thanks again Loren. I'll give the lower number a go shortly.
I tried going up and down by two and no luck. Any other suggestions?
  • Replies 19k
  • Created
  • Last Reply
Top Posters In This Topic
2001 Boxster
CDR-220
Becker 1
Type 4462
24/99
15085036
Please help me.
Thank you
Try 5441
or
5439
Thank you,
Hal
2001 Boxster
CDR-220
Becker 1
Type 4462
24/99
15085036
Please help me.
Thank you
Try 5441
or
5439
Thank you,
Hal
2001 Boxster
CDR-220
Becker 1
Type 4462
24/99
15085036
Please help me.
Thank you
Try 5441
or
5439
Thank you,
Hal
PLEASE READ the FAQ.
2001 Boxster
CDR-220
Becker 1
Type 4462
24/99
15085036
Please help me.
Thank you
Try 5441
or
5439
Thank you,
Hal
Loren,
I got my local dealer to look it up. Cost me a few bucks but oh well.
The code is 6543 for your info.
Thanks again for the help.
Love this site by the way.
I would like to request help in getting a radio code for my 2000 Boxster. I changed the battery and am now locked out of my sound system! The radio serial number is x5026234, then 48/98. The radio is a CDR220 type 4462.
Any help would be greatly appreciated!
Try 4820
or
4818
Hi - disconnected battery to fix window regulator - and not got my radio code - oops!
Becker
Type 4367
X5017853
49/98
Many thanks
:renntech:
Hi there,
Aonther owner request for a lost code...
1999 C4
CDR22
Becker 4467
S/n Y5028998
Any help is appreciated...
Cheers
Neil
I would like to request a radio code for my 02 Boxster 2.7L, I just changed the battery and am locked out of my sound system.
Becker CDR-220
Type: BE 4362
S/N: 25006415
Thanks, much appreciated.
Luis
Try 7020
or
7018
Thank you loren. Ill try it as soon as i get a chance and update the post.
Thank you once again. 7018 and 7020 did not work, i did try ±3 with no luck. I noticed that if i turn the radio off and then on after TWO failed attempts, one is able to try two times as long as you don't enter the third time and fail. The radio will display the "wait" message but it only displays for about one minute. Since i figured that out and didn't have to wait one hour I randomly entered the code 7029 and my radio worked. Thanks a lot, hope this helps save you guys some time. :renntech:
Edited by luisjara986
Hi Loren.
I have a 1999 Boxster and need the radio code. (replaced battery)
Becker CDR 210
Model# 3297
S/N W5023174
Thanks in advance, really appreciate your help!!!! :)
-Theo
New car... replace Battery, no code anywhere... sound familiar?
2002 Boxster S
Becker
Type 4462
SN# Y5042458
24/99
Thanks for your help
Hello Loren,
1999 Carrera
Typ: CDR 220
Model: BE 4462
SN: X5013070
Thank you in advance
Marlin
