Greetings,
I am in dire need of assistance as well. Thanks, in advance, Loren.
Becker 220
Model 4462
Ser#: X5016730
Have a pleasant one, all.
  • Replies 19k
  • Created
  • Last Reply
Top Posters In This Topic
I as many before have done the battery change thing only to find I do not have the code to unlock my radio. Any assistance will be greatly appreciated. Here is the information that you request.
Porsche Boxter 2001
Becker CDR 220
Type: 4462
Ser: 15063242
Thanking you in advance.
Porsche Boxter 2001
Becker CDR 220
Type: 4462
Ser: 15063242
Try 8534
or
8532
Hi, I hope someone can help. I just had my car painted and they disconnected the battery and now I have lost the radio code. this is the info I have found. I'm not sure how to go about getting it. Any help would be appreciated.
Becker 1
type 4462
# Y5038582
24/99
Hi Loren,
Car finally fixed, however no radio code left by the previous owner. Can you help?
Becker 1
type 4467
# 15004219
24/99
Much appreciated!
Regards,
Sebas
Hi Loren,
Becker 1
type 4467
# 15004219
24/99
Much appreciated!
Regards,
Sebas
Try 5080
or
5078
#5080 did the trick, tunes are back! :D
Much appreciated!
Sebas
Hi Loren,
I have a 2000 Boxster with the radio locked. I'd really appreciate if you can help me to fix it:
2000 S
CDR-220
Becker
Type 4367
Ser # Y5021978
Thank you in advance.
Can
Hi Loren,
I was hoping you could help me. I had to replace my battery but have lost my radio code.
Radio CDR220
Type 4467
Serial X5020446
Iain
Try 5072
or
5070
Hi Loren,
Sorry for the delayed response. Thanks for the above really appreciate your help the code was 5074.
:thankyou:
Cheers
Iain
Hi Loren,
I have a 1999 911 Cab with the radio locked. I'd appreciate it if you can help me find the code.
CR-220
Becker
Type 4362
Ser# W5007570
Scott
Hi Loren,
CR-220
Becker
Type 4362
Ser# W5007570
Scott
Try 5238
or
5236
I appreciate the fast response, but neither of the numbers worked for me. It's possible that I messed something up on my side, but do you have any other codes for me to try?
Scott
Hi Loren,
CR-220
Becker
Type 4362
Ser# W5007570
Scott
Try 5238
or
5236
Scott
PLEASE read the FAQ.
Hi Loren,
CR-220
Becker
Type 4362
Ser# W5007570
Scott
Try 5238
or
5236
Scott
All set now, thanks
