  • Replies 19k
  • Created
  • Last Reply
Top Posters In This Topic
Hey guys,
Got back my 2001 Boxster S from the indy mechanic today, overall they've done a good job getting this puppy running well again.
Unfortunately they disconnected the battery to put on an alternator pulley and accessory belt idler pulley so now I need the radio code
CDR 220
Becker 1
type 4462
Serial # y5048180
Also after you enter the code do you have to press anything special or just the code, I used to have a miata that required pushing some stuff after the code.
Thanx in advance
Edited by neurojame
Hey guys,
CDR 220
Becker 1
type 4462
Serial # y5048180
Thanx in advance
Try 9609 ...........
Hi Loren. I need a reset code for 99 boxster.
Type: 4462
Serial number: X50 18249 or X60 18249
The second digit is unclear due to LED light out.
Thank you,
Paul
Type: 4462
Thank you,
Paul
Try 1480
Hello.
Dead battery, lost radio code.
I'm looking for the code for the following:
Becker CR 210
Model: BE2182
S/N: T5001430
Hi, I hope someone can help me. My Porsche boxster had battery failure and now the radio won't work. It is a Becker 1, 4467, SER 15001327. Can anyone give me the code to get the radio working again. Thanks
Try 6763
Hello.
Becker CR 210
Model: BE2182
S/N: T5001430
Try 4756
It works!! Thanks!
Try 6763
Hi Loren, thank you so much it worked!!!!
