Could you please send a radio code for a Becker CDR210 radio in a 1997 Porsche Boxster
Radio Model # R 3297
Radio Serial # W5020410
Thank you very much!
  • Replies 19k
  • Created
  • Last Reply
Top Posters In This Topic
Try 4786
Hi Loren
Bought a new (for me) 993 95 Cabrio with missing code.
CDR-21
Model No: BE2280
Serial No: T5000775
Many thanks in advance. Hope you have time for this.
Cheers
Henrik
Could you please send a radio code for a Becker CDR220 radio in a 2001 Porsche Boxster
Radio Model # BE 4462
Radio Serial # 15063210
Thank you!
Thank you!
Try 8278
Hi LorenBought a new (for me) 993 95 Cabrio with missing code.CDR-21Model No: BE2280Serial No: T5000775Many thanks in advance. Hope you have time for this.
Try 6542
Lost code on battery reset:
CDR-220
Type: BE4462
SN: 25011894
Try 0789
This worked,thank you very much for your help!
srwert1, on 18 Aug 2013 - 1:54 PM, said:snapback.png
Thank you!
Try 8278
I tried that number first as well as:
8288 and 8378
Thank you!
Try 8278
8288 and 8378
Did you use the serial number method in the Lost Radio FAQ?
If not, please do so and report back the correct serial number.
Thank you!
Try 8278
8288 and 8378
OK Loren,
I went back out to the car this morning and tried that number again and viola. 8278 did the job this morning.
Thank you so much for the help.....
Loren , just wanted to ask before i unhook the battery again. I have to fiinish some work on drivers door and gona unhook the battery but if i do, will the radio code be the same cade that u provided before to reset the radio?? thank ahead of time!! im also tryn to reset the check engine light and airbag.
i have been trying to locate the proper software for the scanner but no luck yet.. i will prob order an autel scanner but it will take a week to get here!
Yes, the radio code stays with the radio - so as long as that same radio is in the car the number I gave you will work.
Becker 1
Type 4462
Ser Y5046192
24/99
CDP2081
Thanks so much for the help!
Try 0910
Worked perfect. Yall are awesome! Now I just need to get past the fact that I'm not getting any audio out as I my connectors don't match up from the PCM1 on a 2001 Turbo.
Any input Loren, you seems to know the most about a lot of this stuff.
http://www.renntech.org/forums/topic/44892-need-help-converting-from-pcm1-to-cdr220/
(I posted a couple places just b/c I figured this is a rare issue as I haven't seen any threads of people converting from a PCM1 to a CDR220 anywhere)
Hello.
Have just bought a Boxster without the radio code.
Very grateful for help.
My radio has the number:
Becker CDR 22
BE 4467
W5002435
Regards
Jonas
Hello.
Becker CDR 22
BE 4467
W5002435
Regards
Jonas
Try 4606
