  • Replies 19.1k
  • Created
  • Last Reply
Top Posters In This Topic
I own a 2001 Boxster and it looks like the radio has been replace since the code with the paperwork does not work. Any help would be appreciated.
Becker 1
CDP2081
24/99
Ser- 15076764
Type 4462
Becker 1
CDP2081
24/99
Ser- 15076764
Type 4462
Try 4965
Becker 1
CDP2081
24/99
Ser- 15076764
Type 4462
Try 4965
Hello, I would appreciate getting my radio code for the
type: CDR 220
Model BE 6625
S/N 15009969
thank you!
Edited by garnaud
Hi Id really appreciate help with my code. Porsche supplied code doesnt work. Loaned car to brother in law and he/my father in law disconnected battery :( (actually my bil couldnt start the car so he got my fil to try a different battery -> the actual problem was the the car had been parked with the steering wheel turned and it was up against the steering lock - not actually a battery issue; all he had to do was get the wheel off the lock by turning it to take the pressure and it was fine!)
CDR220
type 4462
Ser 15009664
CDR220
type 4462
Ser 15009664
Try 9710
CDR220
type 4462
Ser 15009664
Try 9710
thanks heaps.... worked.
HI I don't have a radio code for my porsche and I don't know where to find the serial number or anything that is needed to get the code for my radio. I purchased a 2001 Porsche Bosxter couple days ago and the original owner didn't have it with them. Help? Thanks
Edited by Danmak
Please read the Lost Radio Code FAQ
Hi I'm looking for the Codes for my 2000 Boxster S CDR-220 Becker Type 4462 Ser# Y5040160
Any help would be appreciated - battery was changed out, car is new to me and there is no card anywhere . Thanks
:renntech:
:renntech:
Try 8548
Hi looking for codes for a 2001 Porsche Bosxter
CR-220/CDR-220
Serial number: X5021003
Becker 1 type 4462
:renntech:
Try 8548
Many thanks ! works like a gem !
Just suffered through removing the alternator to replace a broken oil fill pipe, and got a surprise from my radio once I was done. Followed the instructions and have this info:
CDR220
Model 4362
Serial 25006971
Any help is appreciated!
Edited by BReif61
CDR220
Model 4362
Serial 25006971
Try 7374
Hi Loren,
I don't need a code yet. The radio is working fine, but I did want to know Is the radio code printed on the bottom of the build sheet on the frunk lid? I just got my first Porsche, an 04 S about two weeks ago & just love it.
Hi Loren,
Not from the factory but sometimes an owner or tech write it there. Still not reliable as the radio may have been changed out.
Use the method in the Lost Radio Code FAQ
Loren:
I have a 1999 996 with CDR 220, S/N Y5060715, model BE 4462.
Could you send me the code? I replaced the unit and am putting it back.
Thanks very much.
Rick Durrett
Loren:
Thanks very much.
Rick Durrett
Try 2378
