and yet another one. Stupid thing is the previous owner gave me the radio code and I carefully put it away....somewhere...... It's safe I'm' sure, but the radio is dead.
Becker 1
4462
15086224
much appreciate the help
  • Replies 19k
  • Created
  • Last Reply
Top Posters In This Topic
Becker 1
4462
15086224
Try 4740
Thanks Loren, but I have now got the right sn. BE 2580 ca 451332363 and call 3 porsche dealers and they all were unable to supply correct codes. any ideas?
Try 6861
6861 didnt work, thanks anyway :)
You did not read the Lost Radio Code FAQ...
"Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM?s require two codes, the ICS/Siemens code and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM code is from a dealer/OPC."
I did read it, and i said 3 porsche dealers were unable to give me the codes i need - hence why i am searching forums for codes - otherwise i have no music in the car :(
Hello,
I changed the battery on my wife's 99 Boxster and I killed the radio in the process. The information I have on the radio is that it's a Becker 1 CDR-220 / Type 4462 / Serial# Y5050028 24/99. Any help will be greatly appreciated.
Hello,
Try 0324
Thank you so much for getting me out of the dog house! That code of 0324 worked perfectly. You are truly awesome!!!!
Hi there,
Anyone can help me recovering the code of my Boxster radio?
The model is: BE 4761
The serial number is: 15010026
Thanks in advance!
For Traffic Pro with 6 preset buttons... try 21212
Hi there,
Thanks in advance!
Hi there,
Thanks in advance!
It works.
Amazing!
Many thanks!
Hi Loren,
just imported a 1999 Boxter back from California to Germany. The KeyCard is no more available.....and I had to remove the battery for power window repairs....
Can you pls help me with the code for my
Becker1
Type 4462
Serial X5020205
48/98
Great job you are doing there,
Cheers,
Andi
Hi Loren,
Becker1
Type 4462
Serial X5020205
48/98
Cheers,
Andi
Try 2393
Hi Loren,
Just got my 1999 Boxster from the shop and they disconnected the battery. Can you help me getting the code for it?
Thank you!
Becker1
Type 4462
Serial W5007525
48/98
