  • Replies 19k
  • Created
  • Last Reply
Top Posters In This Topic
Hi I can not find my wireless card in my Boxster, I would appreciate you to help me.
BECKER CDR 22
MODEL No: BE 6621
Serial No: 15005130
Try 0594
Oh no!....9870 did not work. 8^(
99 Carrera
vin # WPOCA299XXS652520
CR-220
ser. # 5003085
31/98
Sorry, my mistake... try 0210
Worked perfectly! What they say is true.........you are the BEST! Thank YOU!!!! Will donate!
Hello Loren!
Firs post. Was a lurker until today - bought my first Porsche ('99 996) today and, usual story: no code.,,
Becker 1 Type 4462 24/99
S/N: Y5045284
Thanks very much in advance for your time! This is greatly appreciated!!
Try 9094
Worked perfectly. Thanks again, Loren!
Hi I cant find the code to my radios .. Its a CR-220 SN # 15005323 Model N0. BE 6624 TYPE CCR 220 ...
I also have another radio its CDR-220 .. SN # Y5060963 Model BE 4462 ...
Can anyone assist me in getting these codes i would appreaciate it.
Mark
Mark
For SN # 15005323 try 2891
For SN # Y5060963 try 8709
Have a 1994 gts 928...Radio comes on thats it...It has 1-6 radio channels....this is what is on the radio when i had it pulled
Model....cr-1
pno=993.645.104.00
s/no=pocr-1p0816689
vgos16689b
Any help would be appreciated....dont really want to change the radio....thanks
Edited by homey
Model....cr-1
pno=993.645.104.00
s/no=pocr-1p0816689
vgos16689b
Try 0781
Model....cr-1
pno=993.645.104.00
s/no=pocr-1p0816689
vgos16689b
Try 0781
I only have 1 to 6 buttons on it....
Model....cr-1
pno=993.645.104.00
s/no=pocr-1p0816689
vgos16689b
Try 0781
Sorry, you did not read the Lost Radio Code FAQ -- we do not have information for that radio (CR-1)
Loren, just bought a 2000 Boxster with lost radio code. It is type 4462 serial # is X503259. Hope you can help with the code. Thanks.
Try 8670
Try 8670
No luck with 8670
Try 8670
No luck with 8670
Did you get your serial number using the procedure in the Lost Radio Code FAQ?
Try 8670
No luck with 8670
Yes, just went out and rechecked. I left off one number it says serial# X5032591. I left off the 1. When I go through the FAQ process it says 4462 then 48/98 then X5032591 then CDP2081.
Try 8670
No luck with 8670
For the correct serial number try 0253
Try 8670
No luck with 8670
Ok thanks, Im locked out now. Ill try when I get home. Thanks again.
Try 8670
No luck with 8670
0253 Worked!!!!!!!!!!!!! Thanks a million. I now have tunes.
Hello,
I have a 2002 Boxster S CDR 220 and need the radio code.
Model: BE 6625
Ser#: 15009365
Efren
Hello,
Model: BE 6625
Ser#: 15009365
Efren
Try 9386
Worked great.
Thanks for the quick response
