  • Replies 19.1k
  • Created
  • Last Reply
Top Posters In This Topic
Hi. New member, have a 99 C4. Could you get a code for me? Type 9362 serial w5002574. Thank you so much.
Model of your radio? (what it says on the front panel)
Loren, you are amazing. Thank you for the work you do.
I need the code for my 2000 Boxster.
Becker CDR-220
Type: 4462
Serial: Y5041438 24/99
Thanks in advance.
Becker CDR-220
Type: 4462
Thanks in advance.
Try 4820
Make:MERCEDES-BENZModel::CD MF2910 Part number/Model::MF2910 (x8207926)Manufacturer::ALPINE
Did you read the Lost Radio Code FAQ - I think not. Porsche (Becker radios only)
Becker CDR-220
Type: 4462
Thanks in advance.
Wow. It worked. You are amazing. Thanks!
Becker CDR-220
Type: 4462
Thanks in advance.
Wow. It worked. You are amazing. Thanks!!!!
Hi Loren - I have a 2000 Carrera 4.
Becker CDR 220
type 4362
serial # X5019535
Thank you so much!
Just replaced battery and now no tunes any help would be greatly appreciated. Model cr210 R3297 serial # w5012079 thanks again in for any help.
Try 0252
The battery died in my 996 and I can't find the code!
My radio serial number is: Y5025845
Any help much appreciated :)
Try 2972
Thanks so much! Worked perfect :D
